what do i sacrifice when i crank up my keys?
bowtiefreak
No Quarter
Near Philly
Not everyone. Mine are set in the same place they were from the factory. You do not need to crank the keys...unless you want more lift.
fyremanpat
Fyremanpat
im willing to bet they are cranked more than stock...even just a little. for the fact that that have to come off for a suspension lift and you have to get an alignment afterwards...i have a solid inch and a half to two inches over stock torsion crank with NO problems at all. 120k miles on original tierods and ball joints
bowtiefreak
No Quarter
Near Philly
We marked them before we took them off so they are about as stock a setting as can be with removing them. But I see what you are saying. Keep in mind I run a DC 6.5" lift which is a true 6.5" lift with no crank. Most other kits require a crank to get to the height they advertise.
newmarketeod
I ran mine cranked 2 inches (RCX 6 inch lift, wich is just a 4 inch drop bracket that you have to crank your T-bars) for two years with no issue. When I had the front end apart I replaced all balljoints and tierods and just had it realigned and no signs of loosening. It will wear faster than usual but it isn't super fast like it may come across.
And as for the rougher ride, its a lifted full size vehicle, suck it up sally.
iaminfiji
