What is this leak?
Michigan
1E9228AB-AE15-4C6B-A740-0E1AFA6E2F00.jpeg F304D58A-3889-4D43-8403-2D2899E0BAA6.jpeg B7816DEF-AC23-4C7A-A6AB-59C1A5ECB46C.jpeg 1E9228AB-AE15-4C6B-A740-0E1AFA6E2F00.jpeg Hey guys, I have a leak in my 04 tahoe z71. 4x4.
What exactly is leaking here from the pics? I have an idea from a little research but want to be for sure so that way when I take it in to a shop I can act like I know what I’m talking about. Lol.
Also what is the procedure in fixing this leak? Is it just a gasket and how much should a shop charge for this?
HiHoeSilver
Away!
Chicago
View attachment 206144 View attachment 206142 View attachment 206143 View attachment 206144 Hey guys, I have a leak in my 04 tahoe z71. 4x4.
Hard to see in the pics. Is it gear oil (smell it). If so, id say it's most likely the pinion seal on the diff.
Michigan
Michigan
Thanks guys. I just spoke to a shop so I’m going to drop it off tomorrow morning.
Dumb question but is there fluid that will have to be drained and filled back up?
What is a reasonable shop price for this?
off the top of my head I think you should be able to get out the door around $3-400 if there doing the bearing and seal but I could be wrong and yes it takes gear oil, to do the pinion bearing the carrier has to be pulled, so they have to pull off the wheels, pull off the brake calipers, pull the rear cover, pull out the axles, pull out the carrier and then they can access the pinion, so it's a little bit of work. if there is issue's with the carrier then you could be looking at up to or around $1k depending on what needs to be done. if it's just the seal that can be done from the front and is much cheaper.
Michigan
Michigan
035BB4CE-C9CF-4106-A8D9-5DFC434CA700.jpeg 0B67502C-F927-4FE5-8156-4DCBFA821C20.jpeg 366BCB8A-8C09-41A7-9C81-8B2E7ABD6C90.jpeg E7D72ECC-B8DF-4A4D-9FEA-B76398776080.jpeg 3C6B2AA8-262C-489A-BFF9-97E4FDA1A28A.jpeg Ok guys so I just drove home a half hour drive and parked and got underneath the truck with the light on my phone and this is what I seen.
It doesn’t look as if the leak is coming from the pinion, sorry for misleading. It’s coming from right above the pinion. Not sure what part this is. Unless it’s leaking from somewhere else and just flying up there as I drive
What pan is to the right side of the pinion in the last two pics?
I layed down some cardboard so I will try to smell/inspect tomorrow morning.
Ps I didn’t take it to the shop this morning
legit_b
