What is this noise!?
BEEMDUB
BEEMDUB
PIMP DADDY FLEX
Michigan
Does noise get worse in a turn? If so probably wheel bearing.
nope makes no difference through the turn, and the noise stops whenever the breaks are applied...I didn't have my jack stands at my house yesterday so I said forget it and just dropped it off to the shop I take my truck to for everything and they're going to fix it.
mattjones
VA
I think I've got the same problem as you. My sound doesn't really go away when I speed up though; rather its more like the engine just gets loud enough to drown out the squeak. Definitely seems to be coming from front driver side wheel area though.
DwDrummer
AL
How old is your brake pads? When mine got worn out they made a bad squeaking sound.
BEEMDUB
BEEMDUB
PIMP DADDY FLEX
Michigan
Yea the bad noise is actually my REAR left brake pad and rotor....My warranty gets activated tomorrow so after that gets figured out I will be taking it to the dealer and getting new pads and rotors.
GM Customer Service
Michigan
Hi Zach,
Keep us updated on how everything goes at the dealer!
Marissa
GM Customer Service
08grey
Carefull. Most warranties don't cover brakes and rotors.
