What is wrong with my a/c????
fatnlowtahoe504
New Orleans, LA / Hattiesburg, MS
ok so now its getting hot outside and starting to need the a/c, well no cold air is coming out, my heater is still working fine though, my a/c compressor is not coming on at all and i have checked all the fuses and plugsand they are good.....yall think the clutch went out? i am able to spin the front piece of the compressor, idno if that is supposed to be harder to turn or not...what can yall tell me?
hassoun
Germantown, MD
i've had a similar issue with my 01 Denali. turned out the AC belt was ripped and gone somewhere on a highway haha. the ac compressor was hard to turn by hand but once i put the new belt on it spun perfectly fine. i assume your belt is still on the compressor since you tried spinning it correct ? if the belt is on, turn your AC then shine your light on the compressor and watch it for few secs. if it doesnt spin whatsoever then its a bad compressor. hope that helps
redemn93
Jupiter, Fl
with the car running and ac on. i dont know if they are but if the clutches on these compressor are magnetic, very very carefully take a long prybar and touch the compressor clutch. it should be magnetized.
BlizzardX23
Sacramento, California
iono bro...I got under my truck yesterday just foolin around with some stuff and noticed my AC belt shredded and hanging off...I need to replace it..but I hear a noise coming from that area...Im hoping my AC pump isnt bad...cuz I replaced it already back in 2007
177mph
Jersey
Keep in mind that most 00-06 NBS yukons, tahoes, and suburbans have the a/c compressor running all the time. Even with the a/c and defrost off. Its no wonder the compressors are failing early.
CaptPat
