What kind of drop should I use?
Red_Raider
Derby, Kansas
I had a quick question for everyone. What kind of drop kit should I go with...2/4, 3/5/, 4/6? I have a set of 24s on my truck currently with 305/35s on them. I really don't want to change the tire size due to I'm really not into rubber band tires. Could I get some advice and some pictures? Thanks for the help!
godoy
utah
Go with the 3-5 your 24s will fit fine it will only rub at full lock,not much, but you can trim inner plastic stuff , I'm not an expert but I think 305/35/24 is the biggest you can go ,
But if I were to start all over again I would want to go with the 4-6 to get a little lower but I bet I would rub more
Sent from my HTC VLE_U using Tapatalk 2
Red_Raider
Red_Raider
Derby, Kansas
Thanks for the info!!! I will be looking to see what the best deal is on buying one. Might even just have it professionally installed.
lordmorgul
