What size torque wrench for 5.3 oil pan and upper control arms?
Sunshine Girl
Sunshine Girl
Here's what Haynes shows for the oil pan bolts (ft-lb unless otherwise indicated):
For a mechanical torque wrench, remember that they are most accurate at the upper end of their limits. In other words, use a torque wrench that has your desired torque in the upper half, or higher, of its torque range. You'll need to look at your desired values for each piece of work, and match the torque wrench to that.
Thank you for that
Sunshine Girl
Sunshine Girl
I got a Craftsman digital 1/2" and that has been really handy! For a consumer version, it is solid and goes high enough on torque for heavier jobs.
The meter is pretty accurate and can display the set torque in any unit you could want.
For smaller jobs, anything requiring really low torque or inch pounds, I use a smaller torque wrench from Harbor Freight.
If it is something fragile and really low torque, I'll just tighten by hand and make sure I don't get carried away.
Thank you for the info
Sunshine Girl
Sunshine Girl
Likely need two to be correct because oil pan gasket is likely inch pounds torque and I know the upper control arms will be foot pounds and I don't ever trust a foot pound torque wrench to be set at 3 foot pounds to equal 36 inch pounds. Plus, Make sure the weight of vehicle is completely on the ground before you torque the control arms. A one time buy at Harbor Freight is likely ok but maybe a little more money and buy Craftsman foreign made. IMO best is anything by Snap-On, Mac, Matco, SK, etc....but is pricey.
Thank you for all the information
GMT430guy
