What to do AFTER carpet cleaning
truestory336
Tan Carpet
The tan carpet (and ALL GM post-bankruptcy carpet) is terrible to try to clean. The Tahoes and Suburbans are the worst. I do this daily for a living and there is no way to completely clean this carpet. Even after steaming/shampooing, you most likely will have to use dye to correct any imperfections. Black carpet is easier simply because it hides stains but the tan is HORRIBLE.
08grey
U need a extractor and a extractor rinse chemical. Pre treat stains with a heavy duty pre treat then extract with a extraction rinse chemical. It should dry fine after. If you want to clean without water you can use a rotary buffer machine with a bonnet and a dry carpet shampoo. This will avoid the recurring stains when dry. Try using professional chemical made for commercial carpet. I only use Johnson diversy products.
Garage2010
