what yall think?
felskee
welll i dont got to much cash so im just gonna get what i can get. is any of this stuff good? i did some research.
Subs:http://www.amazon.com/gp/product/B0028AYIXK/ref=ord_cart_shr?ie=UTF8&m=A3MJ987JELUZUB
Amp:http://www.amazon.com/gp/product/B001QX3WM8/ref=ord_cart_shr?ie=UTF8&m=A3H89ADJHTH9SN
wires:http://www.amazon.com/gp/product/B000Q6DLTK/ref=ord_cart_shr?ie=UTF8&m=ATVPDKIKX0DER
and http://www.amazon.com/gp/product/B001EQQ5LW/ref=ord_cart_shr?ie=UTF8&m=A39GOUEDJMM2SB
this look decent to yall? would this go all together and work? btw i excluding buying the box cause im buliding one.
Should i go ported or sealed?
MOBmentality
Has a $25,000 Punch
I think you should do a hair more research homie.. and ported will get lower and louder.. but sealed will be tighter and more quality sound... so if you listen to jeezey and jock.. go ported.. if you listen to more kanye , nicki , drake or rock... go sealed.. but thats just imo....
Id go jl w1s over infinitys though..if thats your price range... and there are ALOT better amp selections than crunch... try sonicelectronics ..
felskee
felskee
did you ever find out what youre gonna run... there is a bunch dudes on here with some good used stuff too..
well imma run prob a ported box with those subs and amp. i only got 250 to spend.
blueflamed03
Oklahoma
if you can, find a class D sub amp, be more efficient, and easier on your stock electrical system.
fyremanpat
Fyremanpat
I have a single L7 12" dropped to 2 ohm in a 1.5 cu ft ported box running half the rms...(I like the extra space)..and it is way more than enough. its stupid loud when it needs to be. I have had a ton of subs in my day and hands down L7's have been the best. Infinty's are ok, they should stick with speakers and not subs imo.
daddy g
