Whats a good obd2 scan tool that can scan abs and air bags
Anytime. While people call them Chinese clones, the Vetronix ones were made in China and mine came from the same factory. Maybe they all do? There's some basic tests to make sure everything is working and that's what many of those accessories are used for. I just use the Tech2 and the Candi module and the obdII adapter.
Thank you my friend, PM sent.
GeorgesBlazah
South Jersey
Just an update, it reads my suspension code. I can see a bunch of data similar to some of the bluetooth devices but I can also get into the BCM and look at the values of different sensors. I can look at the values of various chassis, engine and body sensors.
ladorn45
Does the tech 2 or blue driver show real time abs sensor data. I don't get any abs fault codes. So I am trying to figure out which sensor is having a voltage drop and triggering my abs to kick in at low speeds. I got the autel but that looks like it won't give me real time data for each sensor as i drive.
The Tech2 does. It can record also so you can view it after a drive, either on the Tech2 or download it to a computer with the TIS2000 software.
Matt_
Which autel do you have? I have the MD805 and can read individual wheel speed sensors.
ladorn45
ahhh I have Autel Al619. I guess I'll return it and get md805. So just to confirm you where able to see each wheel speed sensor while u where driving?
Matt_
Yup, I used it recently to show my friend how his right rear sensor had no output, then when we replaced it how it was working just by spinning the tire by hand while it was still off the ground.
Kerrick k
