Wheel help please!!!
9Tahoe5
Hi everyone im new here, I just baught a 95 4x4 2door tahoe. As you all know it has a lug bolt pattern. Heres the question. Is there anyway to get 5 lug rims to work on here?Reason i ask is i can get a killer deal on a set of foose 22's that ive been wanting for a long time. would doing this be stupid or alright if im getting a good deal......... If its even possible. Thanks in advance.
TigerEyz3
Slow and Steady
TN
It's possible... you'll need to purchase wheel adapters that convert your 6x5.5 pattern to a 5x5 pattern (or whatever the wheel lug pattern is). Just to be clear, I'm not talking about spacers... The wheel adapters will need to be at least 1.5" thick to compensate for the lug length. Not sure of your suspension setup, so this may not work if you're trying to go low and/or tuck.
The alternative would be to redo your axles to a 5 on 5 pattern - easy changeover up front, but requires you to redrill your rear axle.
9Tahoe5
There Foose Nitrous wheels, ive been in love with them forever.
9Tahoe5
seems like alot of work, might as well just buy a new set to fit. Think im just going to go new.
97yukon
baton rouge
ive had adapters and they are a pain. but i agree, depending on the deal...and if you do go through with it..ebay has adapters to use for just about any combination and are very reasonable
Abdey2002
