Wheel Offset
bigblue
bigblue
Beaumont TX
No it won't, that is an issue with lift kits only because the spindles are so much bigger. They also have to increase the track width of the truck so it can properly clear bigger tires if they are installed when turning and what not.
Stock, the front tires stick out more than the rears on these Tahoe (Prob. about 1/2"), and it will remain like that with the 2" drop spindle.
what is the advantage of a spindle drop kit versus a spring front drop kit
Modded
That Guy
Haha I think I have answered that question from you before, spindles ride just like youir car does now, except your front end will be 2" lower, nothing is sacrificed but ride height.
Coils ride rougher than stock suspension and sag voer time, depepnding on what compnay you go with (Pedders and Ground Force def. don;t ahve this issue. Also coils may have alignment issue and void soime warranties here and there, depending on the dealership.
macky
i have +18 offset. they poke out about 1/4-1/2". looks pretty aggressive,especially with the lip i have on my rims
millercreek
Texas
I read somewhere that the McGaughy's spindles are the only ones that GM will cover under warranty. Someone correct me if I'm wrong.
Modded
That Guy
Not really sure about that Miller, I do know the McG one has the best geometry, making it the best spindle for every 07-Up NNBS model so I would not be surprised if its the only one GM supports.
MOBmentality
Has a $25,000 Punch
i am going to be putting 24x9.5 wheels with 305/35/24 tires. I was wondering what offset everyone was running? I dont want my wheels the be sticking out of the fenders
am i wrong or is this a bad tire for a 9.5? the ideal rim size for a 305 is 10.5 inches.. so we are already pushing it doing it on 10s.. i think a 9.5 is gonna wear the center of the tire out quick as shit.. or at least have some weird sidewall bulge..
---------- Post added at 11:16 AM ---------- Previous post was at 11:13 AM ----------
275 is like the recommended size for a 9.5.. so i wouldnt go past a 295.. for sure
---------- Post added at 11:29 AM ---------- Previous post was at 11:16 AM ----------
295/35 is good for a 9.5
or a 295/40 .. 285/40s are ideal... and will still have about the same sidewall as a 305/35
Conor
"Bob's your Uncle"
Seattle, WA
There are no issues with a 9.5" wide wheel on a 295 or 305. Recommended rim width is 9.5-11. I personally would not want to go any wider than a 10 and the 9.5 looks perfect. No issues with uneven wear or sidewall.
MOBmentality
Has a $25,000 Punch
Definitely not calling you a liar just wondering where you found anything saying a 305 was recommended on a 9.5 everywhere i see it the smallest it recommends 10 or larger
jetstar88
Madison, Al
For whatever it's worth, mine are 285/45/22 mounted on a 9.5" wheel. I know yours are 24"...It's all a personal preference, but I think a 305 mounted on a 9.5" wheel looks too wide for the wheel.
[/IMG]
bigblue
bigblue
Beaumont TX
i had just 305/35/24 is what people used on 24 inch wheels, because every site that i have seen that sells wheels and tire package that is what size they offered, so i just figgured that was correct
Stevemo70
