Wheel Rubbing in reverse
V
Vermtown
Yep, only in reverse. All right will do that tonight. Sorry but didn't get "In my opinion, both are totally normal by the way" Not sure what you're referring to :)
Erik G
Houstone Town
Sorry
In my opinion - wheel bearings and tie rods go out regularly with factory parts
01Konvict
Boats n Hoes
Raleigh/SML
It's not wheel bearing and tie rods causing reverse tire rub. The a arms have bushing in them and they flex when vehicle weight is changed when going forward or reverse. Even mine does it randomly on weird angles and such.
Yes the level kit will fix it and make it look better! Measure the fenders before ordering but I'm almost positive that the 1.5" will make it match perfect.
V
Vermtown
Great thanks for all the help guys. I jacked it up last night, no play in either front wheels, both spun fine without noises. Tie rod ends looked like they have grease and functioning normally. Sway bar links looked ok, prolly replace them with all the other stuff at 100,000 miles. I'll post an update with pics when I put the kit on. Probably should have read up on offset before I bought wheels :)
V
Vermtown
Put a 1.5" level kit on last week before thanksgiving. Wheel rub is all gone. Put new sway bar links on when I was in there. Riding smooth now. Having a snow storm now, so pics will have to wait a bit, but it looks good. Thanks for the help
V
Vermtown
Looks better to me. Had an alignment done as well because they were toe in after the lift.
AZSCTACO
Phoenix, AZ
Mine rubs in reverse as well.......no issues with the wheel bearing or tie rods. I'm pretty sure other people rub in reverse only as well. Maybe some others will chime in. Mine is dropped 2/3 with 305/35/24.
NeverSatisfied
eBay Baller
Wichita, Kansas
With 305s on any sort of drop there will always be a little rubbing because of how wide the tire is. I'm a 295/35/24 fan myself but a lot of ppl love the looks of 305 more. With a little trimming or molding of the plastic should take care of the little rubbing
NateW
