Wheel/Spacer Combo Help
RobbieX210X
Don't Hate! V Eight!
New Jersey
My buddy gave me a set of rims from his 98 frontier and they fit perfectly, bolt pattern with stock lug-nuts. The wheels are I believe 108mm bore and I (am looking at) getting a 6mm thick spacer plate with a 108mm bore also (I can't find one with a 78. My truck has a 78mm bore according to the 1.25in adapters I bought (selling those cause I don't feel like cutting the studs.) Didn't plan this out. Would it be okay with the 108 bore for both the rim and spacer? Or will I need to get those plastic bore adapter rings (most likely). I don't think the hub will be long enough to support both the spacer and wheels with the plates in place. The rims rub by a fraction with the calipers and I don't want to shave down the calipers. I have zero technical skill.
These are the plates:
http://www.motorcitybolton.com/whee...5-lug-or-6-lug-wheel-spacer-plate-1-pair.html
There are the adapters I have:
http://www.motorcitybolton.com/whee...-6x139-7-1-25-wheel-spacer-78mm-hub-bore.html
I am currently still trying to figure this out.
Gzes
the drifting 2dr
Wichita tx
Jt doesnt have to match with the bore. As long as its lug centrick its good. My h3 rims have a larger hub but dont affect anything. I dont have the plastic rings
RobbieX210X
RobbieX210X
New Jersey
Thanks Gzes, I'll have to measure and put the wheels on and spin em to see if they rub. Keep ya posted. :Stupid Me:
Gzes
the drifting 2dr
Wichita tx
Just remember to tighten in star pattern so it gets lug centrick of npt it can vibrate
RobbieX210X
RobbieX210X
New Jersey
The spacer plate helped the problem in the front, no more grinding, but the back calipers are different design so now I need to shave a bit off of them. Halfway there!
Ccollins0408
