RobbieX210X
Don't Hate! V Eight!
My buddy gave me a set of rims from his 98 frontier and they fit perfectly, bolt pattern with stock lug-nuts. The wheels are I believe 108mm bore and I (am looking at) getting a 6mm thick spacer plate with a 108mm bore also (I can't find one with a 78. My truck has a 78mm bore according to the 1.25in adapters I bought (selling those cause I don't feel like cutting the studs.) Didn't plan this out. Would it be okay with the 108 bore for both the rim and spacer? Or will I need to get those plastic bore adapter rings (most likely). I don't think the hub will be long enough to support both the spacer and wheels with the plates in place. The rims rub by a fraction with the calipers and I don't want to shave down the calipers. I have zero technical skill.
These are the plates:
http://www.motorcitybolton.com/whee...5-lug-or-6-lug-wheel-spacer-plate-1-pair.html
There are the adapters I have:
http://www.motorcitybolton.com/whee...-6x139-7-1-25-wheel-spacer-78mm-hub-bore.html
I am currently still trying to figure this out.
