Wheels with offset posted!
01Konvict
Boats n Hoes
Raleigh/SML
Hard to see but zoom in on picture to see black trim. Just marked backside with sharpie and then cut down with dremel. Installed and cleaned up lines with sand paper
AppocAlexx
AppocAlexx
Darth Appocalexx
Abilene TX
Will cutting the tabs off make it that much more floppy? If it does I think Ill still cut em off and if anything make a couple brackets out of some left over metal somewhere, I'm sure I can find some around the shop I do my work at.
@01Konvict That does look clean tho. If I had 6inch lift then I think I would feel better with it like yours but all ill have for awhile is a leveling kit. One day ill work on getting a 4-6inch suspension kit. So far out of all the trucks iv seen on here for lifted anyways yours and @Ridechevy09 have always caught my eye the most. Both of you have done good work to your trucks.
01Konvict
Boats n Hoes
Raleigh/SML
@AppocAlexx yes it will make it much more floppy. The bumper is held in place in the center section by the outer most corners of my trim valance. The middle is just to hold valance. The bumper brace inside the fender liner holds the corners from moving. You can make a bracket to mount from tow hooks to fog lights but don't have any suggestions on doing it. Thanks for liking the Denali! I dig Rides Hoe and glad to see some other lifted NNBS around the forum.
Fish-man
Ya, I made brackets into the tow hook area back to the frame. Simple. Cut em off I say
pickegs
