Where to get 12V+ switched
aldrichg9
Hello I have been searching and going through threads and not found anything so.. If anyone knows of a please help me so I am not duplicating threads.
I am putting a Kenwood 7015 in my 03 Denali. (old, I know - but I got it for free today)
I am ditching the Bose and going with a 4-channel and a 250/1 - So no wiring adapters.
Where do I get a 12V switched power for my HU that will keep the radio going when I turn the keyt off before I open the door?
I used to just tap into the fuse panel when I did things half-assed but I am looking for the right way to do it.
Thanks,
Greg
txsmainevent
"The Lurker"
Texas
Are you using a wiring harness? If you buy the harness and wire it up you shouldn't have any issues....I've installed 3 different head units in mine and haven't had to tap into anything.
ScottyBoy
Shreveport, La
The only way to have it stay on until the door is opened is to buy a harness. You can get a Scosche one for about $40 if you don't need the Bose harness. You other option is to run a switched ignition from the pink wire in the ignition switch harness. But it will turn off as soon as you shut the truck off, not stay on until a door is opened. Another dawback of not using a harness is you will lose all signal chimes such as headlights left on, door open, low fuel, etc.
A
aldrichg9
Nope. I'm told the only harness for mine is part of an interface with the Bose and its approx 100 dollars.
Def not going to spend that just to get power.
If you know of a cheap harness that will just get me the basics without forcing me to hook in to the Bose, I'm all ears!
---------- Post added at 09:10 AM ---------- Previous post was at 09:08 AM ----------
You bring up another question I have.
Isn't the chimes tied to the Bose amplifier?
if so I still wouldn't have them, right?
---------- Post added at 09:19 AM ---------- Previous post was at 09:10 AM ----------
This seems nice and easy.
If you can't get it at your radio harness, you can get it at the ignition harness. Should be a thick, pink or pink/white wire.
ScottyBoy
Shreveport, La
The chimes are tied to the radio, which plays them thru the speakers. The harness has a little box with a speaker in it that you hide in the dash and the chimes play thru that little speaker in the harness/module.
And you should be able to use the non-bose harness if you will be bypassing the Bose amps anyway.
This is what you need.
http://www.sonicelectronix.com/item_3775_Scosche-DCGM09-GM09SR.html
Or this one will also work, and is cheaper.
http://www.sonicelectronix.com/item_17325_Axxess-LC-GMRC-01.html
A
aldrichg9
Thanks scottyboy!!
This is exactly what I couldn't find and the local audio shops were telling me doesn't exist!
I appreciate you going out and looking this stuff up too!
TnTahoe
TN
Thats not true I know how to make the radio stay on until you open the door. There is a panel on the passenger side like the fuse panel on the driver side. There is a wire in there that you can tap into.
Sidenote: You will lose all warning chimes though, but thats what the dash lights are for imo.
J_seriesaffair
