Where to get electric fans for conversion?
DaUsedMCR
San Bernardino, CA
I believe the single pin is for '01 and '02's while the dual pin is for '03-up, it should say on their website!! You shouldn't need to overdrive pulley with that alternator but can get it if you want!
Also, get the tune before you install the cable and the fans, that way the computer will be able to control them because Justin will turn that option on during the tune!
will my amps go down at idle without the pulley? ive already been tuned by BB, so do you think they will activate the efans for free? i also wanted to hook up the wiring like gpracer1 did in post 8 on this thread:
http://www.tahoeyukonforum.com/forum/showthread.php?t=28336
anyone know how to wire it like this or does Justin just tell the computer to do it?
Rivieraracing
I had the pulley at first with my fans on my denali, I took it off because it was slightly making the belt slip and squeel and I didn't notice much of a different without it. I think also that the denali's have the 130A alternator so if you have the same I'd think you would be fine without it, but it is cheap to buy so feel free to buy one and try it!!
I wasn't aware that you already have a BB on your truck, Justin should have turned on that pin in your computer when he tuned it, so you should be good to go with a BB harness ( he told me when I got my truck tuned by him that he always turns that option on, but if you wanna make sure email Jenna to confirm this).
---------- Post added at 07:09 AM ---------- Previous post was at 07:06 AM ----------
As for how GPracer1 wired up his fans, my system works fine for me so I've never messed with modding mine, so I can't help you there!
DaUsedMCR
San Bernardino, CA
alright cool, thanks. youve been a great help! i shot Justin an email a few days ago, and he hasn't gotten back to me yet... maybe with xmas coming up hes taking a few days off...
Rivieraracing
Message Jenna on here, she's usually on here a good amount and can probably get you your answer quicker!! My bet is that you already have that pin on due to the tune though!
DaUsedMCR
San Bernardino, CA
Justin got back to me earlier and said it was turned on. so i just install the fans, and the harness is plug and play?
Rivieraracing
For the most part it's plug and play, the BB harness will come with directions but you will have to get power, grounds, tap into the A/C wire, and install the pin but the rest is P&P!! All in all it's pretty easy!
bruh2125
