SFBerto415
I seek help fellow TahoeYukon owners! I am hearing that alternator whine that comes through the speakers when accelerating. I know it has to do with ground connection, but here is the thing: I do not have an aftermarket amp installed in my truck.
(My signature states what I have installed in my truck as my audio entertainment system.)
I have taken it to an audio shop and they recommened ground loop isolators...these GLI helped but didn't eliminate the noise just softened it a little bit, but at higher volumes the noise is very obvious.
Today I was fed up and snapped off the dash and a shell that is attached by two screws under the steering wheel and found a ground wire that the audio shop used to ground my electronics.
Obviously this is not a good ground connection or maybe it is???? This is where you knowlegable people come in.
Should I unscrew this attempted ground connection and screw it somewhere else? Should I add more wire and then run the wire to the negative car battery terminal? Should I cut a small opening in the carpet under the driver pedals and screw it there? I need help folks, this noise is gonna drive me insane and I have a long trip coming up this weekend and it will really suck...
