avalonandl
Timken or NSK hubs.....
How does the Moog CK series Problem Solver ball joint compare to the Delco OEM ball joint? Nearly as good, as good as, or better? I prefer to be able to grease the joints periodically.
I've got the arms, now. Should I replace the control arm mounting bolts, as well, or do you think they're okay to reuse? Thanks.
Thanks, guys, that's what I was thinking. Are there any torque specs for those bolts, or do I just snug them to the control arm brackets on the frame? (I'm assuming the nuts are lock nuts.)
