Which Knock sensor is P0327?
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
no warranty? no way to call and ask what brand they used? no receipt?
in that 2nd video I linked in the comments it seems to be a common issue with none resolved in the comments but one person did mention adding a ground.
I forgot to answer your question. Sounds like they did warranty the repair. He took originally after they replaced the knock sensors and they replaced the harness at that point. I think his trouble is, it's his work truck and he doesn't have any downtime to let them troubleshoot the problem further.
I help him at work and am a bit of perfectionist with such things. I hate to see his engine light going off all the time. I kick myself for not helping him originally despite my worst case scenario fears.
ScottyBoy
Shreveport, La
Also, there is a torque spec for the knock sensors. I can't recall exactly what it is, but I had to look it up when I replaced mine. I read in service data that if they are over tightened then that could cause them to be far more sensitive and detect false spark knock.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Good thought! Yeah I don't recall it either but it's 18 ft lbs or less... maybe even something odd like 11. I remember when I changed mine. They may have torqued them unevenly.
chriskat01
I didn't see an answer to the original question. Bank 1 is the front sensor and bank 2 is the rear sensor. The torque spec I found was 15 ft-lbs.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Thanks, we sorted out the oxygen sensor problem. I think was a loose connector. However, never figured out what side that code is for. Odd or even side of engine.
ST7-OKT
