whistle noise coming from under dash when applying brakes
blackbox19
I have a 2013 and notice here lately that when I put foot on brake there is a whistle noise coming from the petal area.
It does not sound like air coming out of something but more of a hydraulic fluid passing thru a slightly open valve. I came from the Aircraft field and on some of the hydraulic systems you could hear a noise similar due to a unseated valve.
If I press hard it will do it and it I set there hold slight pressure if does it worse. Light setting at a red light.
It does not do it all time and the brakes seem fine otherwise. IF need be I will get a video of the sound to help pin point whats going on.
Turbo T
If I had to guess, I'd say your brake booster is bad. Does the engine stumble a little when you apply the brake while sitting still?
SnowDrifter
Washington. The starbucks side not the desert side
That's a good whistle ya got going there.
Sounds like the brake booster is work out. It's a vacuum operated system.
Un plug and cap the vacuum line going to the brake booster, stomp on the brakes to verify. Dont drive the vehicle when doing this, I just want to isolate its not a bizarre ground loop or something created by the brake switch.
If there's no sound, then you've verified the booster is bad.
276mike
