White smoke issue
NickTransmissions
Sin City
The transmission bench
It appears my name was mistakenly tagged somewhere in this thread and caused me to post a reply that belongs in another discussion.
Lol, thought you were the OP but changed your user name for some reason. And idea of leaking connector hoses causing the white smoke out of the tail pipe was funny.
Nobody tagged you in this thread from what I can see...
RST Dana
OH
He was tagged, but the post/reply was from another topic and was inadvertently in the wrong discussion.
RST Dana
OH
Hi team -
Just heard back from the GMC dealership with the diagnosis: they discovered that the connector hoses are leaking. It's a $3,000 job that will fortunately be covered by warranty. I should have some more information later from them today or tomorrow.
Wrong arena I believe.
C
In addition to the dry/wet compression test, also do a block test that confirms/denies presence of hydrocarbons in your engine coolant. If confirmed, time to yank and go through the heads. If engine has more than 140-150k or so, yank and overhaul it, if you determine head gaskets are needed.
The block test kits are avail at auto parts stores and on Amazon
Mines running about 275k miles right now
NickTransmissions
Sin City
Gotcha, 275k is pretty good for those engines (or any gas engine, for that matter)...If you determine the head gaskets to be the problem (or a cracked head), I'd yank the engine and replace with a reman if you don't have time to rebuild it...Check with machine shops in your area...You may be able to get a 'ready to go' long block for under 3k...From there you bolt on all your engine accessories, install it, fill with break-in oil, prime it and fire it up and you should be good to go for a long time.
Alsherooqi
