Who has high mileage Denalis (200k+)?
optimusprime
I’m in the process of potentially selling my rig (08 Yukon XL Denali) and getting into a 2018. However, I loathe payments and this rig has been awesome for us. I was just wondering who here has rigs with at least 200,000 on the clock and what issues i may expect to deal with after this point. Original tranny but it has a hard 2-3 shift sometimes. It’s got an upper oil pan leak so I’m not sure if that’s the cause of oil loss or if it’s the engine. It still runs amazing and I’ve never had issues with the engine itself. I may just try to doctor it up a bit and fix the big stuff as it comes along and save myself $35k+. What do you all think?
j91z28d1
depending on what's been replaced. there's a few things that will need refreshed soon ish. if you're a diy guy, it's not horrible. bit pricey to have a shop do.
but my 2 cents is spend time researching that 2018. from my reading they seem to be pretty unreliable compared to these, if you like what you have and doing it just for reliability. it might be misplaced.
but new car fever is real haha. the new ones look nice too.
O
optimusprime
I’m pretty handy. I don’t mess with transmissions or tearing the engine apart. Everything else I’m comfortable with. I mean, even if I have to totally replace the engine and tranny, I feel I’m still ahead by around $25k. Just some of my thoughts.
O
optimusprime
I’ve got 208k on the clock. Still runs good. I just go back and forth. I hate payments and this thing has been paid off for a good while. From everything I’ve read, these older 6.2s with no AFM tend to go a long time. Not sure how long that is. The newer models tend to scare me more just with the computer stuff and newer engine things.
j91z28d1
there's a sticky tread somewhere with some stuff to look for buying used. even thou you already own it. most of the same should apply based on how much maintenance you did.
off the top of my head, the torque converter in the tranny replaced if you haven't done it around 125k. when they go out they take the tranny. but if you haven't replaced it yet, and have a hard shift. might be signs it needs it soon and I don't know if tranny damage has been done yet or not.
*edit if you don't have afm. then oil pan gasket always leaks at some point. while there a 5$ o ring is worth doing. rear main and cover would be good to do during torque converter swap.
at that point just fix what goes bad as it happens. my 2 cents if yoh can find someone to thru a new upgraded torque converter in it for reasonable price.. keep it, fix it up and see how far it goes. I sold my 96 tahoe at 325k and it felt nice to hit 300 with it. the buyer is still driving it last I heard.
Geotrash
Dave
Richmond, VA
It's almost always more cost-effective to repair and continue driving an older car than it is to buy a new one - especially when you do the work yourself. When a used later model costs $25K, that's a lot of budget to use for repairs, and the later model one would still require care and feeding plus the occasional surgery, too.
I have an '07 Yukon XL Denali with (as of yesterday) 249,879 miles on the clock. I bought it 6 years ago with 196K on it. The date codes on the engine castings I've seen are 2013, so I believe the engine was likely replaced before I bought it, at some point. There's a mysterious entry on the Carfax for dealer service in 2014. Based on the odometer readings of the prior and subsequent services, it looks like it was out of service for a few months at that time also. The transmission must've been replaced, too - the case casting is dated 2008, so I haven't bothered to replace the torque converter, but I will eventually when I have the transfer case rebuilt, just in case. In the time I've owned it, I've replaced:
1/ Driver's side valve cover to get the newer style internal baffle that stops oil consumption issues. (Might be your issue, too).
2/ Rear air shocks and compressor
3/ Front control arms, ball joints, tie rod ends, stabilizer links.
4/ Front diff mounts
5/ Alternator
6/ A/C compressor
7/ Radiator, hoses and coolant tees at the firewall
8/ Starter (started clinking against the flexplate)
9/ Front brakes and rotors
10/ Battery
11/ Left front wheel hub
12/ Oil cooler bypass plate with an ICT billet design that uses an o-ring instead of a gasket
13/ Steering rack and hoses
Still needs:
1/ Transfer case rebuild to take out the slack in the chain
I did all of the work myself so I probably have less than $3000 in parts in it. Apart from the transfer case slack, it's tip-top, so I wouldn't hesitate to drive it anywhere. Just took it on a 400 mile round trip on Tuesday. It's also worth mentioning that only the alternator going out would have stranded me had it not happened in my driveway. The rest of the issues all gave plenty of warning so I could do the service when it fit my schedule.
Finally, it's worth plugging the money you would spend on a 2018 (including interest costs for the life of the loan) into a compound interest calculator. So, figure $30K total for a $25K loan, and look at what that money will be worth when you hit retirement age. Hint: it's $116K after 20 years. That exercise alone has spared me from a ton of poor financial decisions over the years.
Net/net, I'm in the keep it and drive it camp. Treat her like a lady with proper care and love, and she'll always bring you home.
Edit: Just thought of another thing that's been on my mind: cylinder heads. Specifically, the 823 heads have been known to drop a valve seat once in a while - particularly if they have ever been overheated. And there have been a few cases of valve spring failures on the 6.2's as well. Neither are common, but it's not a bad idea to consider a new set of factory springs as a maintenance item, and I always let my engine idle for a few minutes to cool the heads down, like when pulling into a rest area.
donjetman
https://www.tahoeyukonforum.com/threads/what-ive-done-to-my-yukon-denali-the-past-18-months.118329/
Has not "required" much since, but I do enjoy fixing things before they break (proactive not reactive).
Put my user name "donjetman" in the search function here and see it all w/pics.
We're still lovin it but its not getting used to drive back forth between our 2 homes that are 1000 miles apart anymore. We bought a low mileage 02 Corvette and it's getting that duty.
Today it has 200k miles, consumes no oil, drives like a dream still. The only time it has let me down was when a heater hose plastic T broke 8 miles from home. I was carrying new billet aluminum Ts in the seat back but had procrastinated too long about installing them. :(
2004BeastMode
