This one you only need to be concerned about the first part about the ridge removal. Anything else that's on either of those tbi mod links either doesn't apply to your truck or is just wasted effort.
Before you remove that spacer riser plate you will need a new air cleaner assembly. Preferably a flat bottom style as without that riser plate the stock air cleaner housing will hit the linkage and other parts.
Will do the ridge removal. Thanks.
I thought if I get the TBI spacer (between the TBI and the intake manifold) that would make up for needing to get a different air cleaner assembly? I could be wrong, though.
I have the same year truck as you do and have owned it for ten years. I too thought about getting rid of the TBI but its to much work and expense. These are low HP motors but very reliable and dependable, they are not intended to be fast notice the red line. The TBI seems to dump more fuel into the motor than the Vortec injectors and you end up with more Fuel Vapors in your oil. I have the same fuel smell in my oil after every oil change and I change my own oil a lot. I have replaced everything on the motor as far as tune-up parts go and would suggest you replace all the distributor parts including the Control Module if you have not already.
Glad to know someone else has been keeping these wonderful trucks in great shape. Mine was completely neglected. No one wants to do their own work anymore which leaves (most of the time) shady mechs doing crappy work on top of other mechs crappy work. It all piles up and I'm the one fixing everything now.
So for the distributor parts, I have done the cap, rotor, wires... what else would you recommend? A list perhaps? Thanks. (I can see the Control Module you recommended.)
A little 4V carb (Holley 600 VS with electric choke) on top of a phenolic spacer on top of a performer RPM/equivalent intake with a GM HEI distributor and you can dial in your fueling and ignition with MORE ease than you can with a TBI. You can more easily modify the spark/timing curve with weight and spring changes. You can more easily adjust the idle mixture, idle speed, and air/fuel ratios. There is also no burning chips or piggybacking computers to program "tunes", you actually tune it yourself with tools you already own.
Yeah, I appreciate the advice. I guess I've just determined after finding out how badly this machine was neglected that any kind of major mods are too far off in the future to think about right now. Thanks tho. About the burning chips and piggybacking and tuning chips etc thats exactly the crap I didn't want to have to deal with. But again, that's too far down the road for me to be dedicating budget and brains to it.
NEW: So after changing the thermostat, come to find out, there wasn't one in there before. They had just the stat housing metal piece but no actual stat. So after putting a 195* stat in it, it now runs extremely hot, even almost reaching 265*. What I'm thinking is that they told the guy they put a water pump in it, but didn't and just put the stat core in instead. When I squeeze the upper radiator hose, it feels pressurized and doesn't flow freely. So new water pump??? Thanks
Also, the oil pressure is running almost at 0 at times. This worries me because I have a noisy lifter and no oil pressure sure isn't going to help it any. Ideas? Thanks.
