HiHoeSilver
Away!
I didn't know anyone ever ran cleaners through transmissions. I know many DIY'ers at home just drop the pan to change the filter and refill whatever fluid was lost with that. But there's still all that old fluid elsewhere in the trans and torque converter so dropping the pan only replaces about half.
I've seen shops use machines that basically refill the trans with new fluid as the old stuff is pumped out. Maybe this is what the call a "flush". Not sure if any run a cleaner during this process.
I pop off the hose that the fluid takes from the cooler back to the trans and have it drain into a large pan. With the engine running and trans in
"Neutral", I pour new fluid into the dipstick/fill tube (using a funnel) as the old fluid is pumped out. I continue this until the fluid coming out is the same color as the fluid going in, then continue for a quart or so to make sure. Then I change the filter, draining the trans pan into a clean pan and being careful to save as much as possible to re-use, then top off the fluid. I wouldn't consider this an aggressive "power flush". It's just a total fluid replacement.
I did mine similarly. I hooked up to the cooler line and pumped out the pan (4-5 qts). Then I dropped the pan. Changed filter, seal, gasket, and clean pan. Filled through dipstick, pumped, filled, pumped etc until clean. Ran it. Topped it off.
