Wierd sound when pressing gas pedal.
ravingmadman
Chief Knuckle Buster
Greater Seattle
Fire up your truck cold, get underneath it, and run your hands closely around the exhaust pipes. Don't touch them, they're hot. Where the exhaust pipe splits to go to all the cylinders, is the exhaust manifold. This is an easy check to do that doesn't require swapping fluids. Swapping fluids is your next bet.
Bad bow tie
Grizz Straight FTMFW
Michigan/NC
If it's a ticking sound, more than likley it is your doughnut gaskets. These are the exhaust manifold gaskets they are talking about. Mine does the same thing, just haven't got around to replacing them.
---------- Post added at 02:21 PM ---------- Previous post was at 02:19 PM ----------
I know 992dr replaced his and documented how do them. Just search it.
Blesna
