Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
The spring is the same dimension and will physically fit but it's rate is different as the 07+ is heavier. So it will fit but the a$$ will probably sit higher than if you used the right spring for the truck.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
