Will 285's Fit?
Justinj360
I just want to clarify if my new 285/70R17 tires will fit fine on my 2004. I was told by a couple shops that they'll fit with stock height. I do have a 2" suspension lift anyway. The first shop refused to put them on and I'm sitting in the second one now stressing out about these damn tires. Will I get any rub even when the suspension is moving? I've heard you have to clip the end of the plastic piece on the bottom of the front bumper but I'm fine with that.
Thanks for the help guys..
TheAutumnWind
What 2" lift do you have?
At worst youll rubb a little and you can trim it.
Mr. 960
I've got the next size down LT 275 70 17 with no problems at all. Should be fine.
Mr. 960
Justinj360
Justinj360
Thanks for sharing the chart! Its a Rough Country kit with 2" spacers and 3" keys but they're only cranked up about 2".
Well they fit fine and so far it appears that the guys in the first shop didn't have a clue. They were positive it couldn't be done. And the second shop was positive it COULD be done.
This thread will be good reference for anyone stressing about the same thing.
jough
Arkansas
I can attest that 285 70 17s will fit with the keys cranked 2".
ccapehartusarmyINF.(ret)
Gilbert AZ
okay im stuck on the fact that a tire shop wouldnt put on tires athat are only what ? 2 sizes larger then stock tires especially since there only 1 inch larger in diameter
plus i know the discount tire i go to is pretty spot on but most tire shops ive ever done business with or gotten quotes new exactly what sizes would rub and what wouldnt
Justinj360
Justinj360
Well it wasn't really a tire shop, it was ******* Walmart. I know, I know but they were really cheap and I thought they could handle it. But I was under the impression that their shops are supposed to be a separate chain company. I don't know if that's right.
TheAutumnWind
It's Wal-Mart, what did you expect?
Those kids have no clue what they are doing.
Sent from my HTCONE using Tapatalk
memphizhoe
Do any of you guys have pics of the 275 and 285s already on ? I'm sure I could research but I honestly rather just ask cause I know yall have experienced it first had . I'm thinking of lifting my hoe and running a 275 or 285 on my sock 17s . Just wanna kinda see what it looks like before I bite the bullet .
Joe-ty
