Will I run into problems putting a 99 4l60e in my 97 Tahoe?
TempestT-37
Palmer, Alaska
I have what I think is a 99 4l60e. I want to put it in my 97 Tahoe. I am wondering if I will have any problems put this transmission in my Tahoe.
The numbers on what I think is a 99 transmission are
24206579 bell
24207965 case
9LU D7
When Using the website
https://www.novak-adapt.com/knowledg...utomatic/4l60e my bell housing is the "1998 Bellhousing with added holes for the bottom cover"
http://mmerlinn.com/catalog/lilscrib...6/gm9l6010.htm it looks like his a 1999 tranny.
Rob Scariano
Omaha
24206579 bell
24207965 case
9LU D7
It should be compatible. Some 97's had the one piece transmission left over from 93-97. However, starting from 96, Chevy offered a two piece which allowed you to remove the bell housing.
From what I can tell, I don't see any issues with compatibility. However, here is a link to a very good video which will make you a 4L60E expert to the sorts.
Worth watching if your making a purchase. It's 20 minutes but it covers the 21 + year life and evolution of the 4L60!
TempestT-37
TempestT-37
Palmer, Alaska
The video has some great information. When I get home tonight I will check some numbers that I did not know about to find out the year. Thanks again.
TempestT-37
TempestT-37
Palmer, Alaska
Now it looks Like its a 98, this is the numbers between the tranny pan and transmission mount. 8TAD258J 20474654
Thank you for your help. Hopefully this post can help others.
Rob Scariano
Omaha
I have heard that the 98 4L60 may not be compatible PCM wise. I would double check before you buy it. Any solid transmission shop should know.
Gm_guy
