Depends on your rim size and offset. I had the same size tire on a 22x9.5 rim with +30 offset and they rubbed just a little bit in the front at about 3/4 turn. As the tires wore down after 5k miles, the rubbing stopped. That's how minimal the rub was.
Also the truck wasnt lowered at the time. Forget about that size if you plan on lowering.
