Winter time squeaks..
fatnlowtahoe504
New Orleans, LA / Hattiesburg, MS
ok so its starting to get a little colder outside and when my motor is still cold including the pulleys they squeak for a little while before the motor warms up, what are yall using to spray on your pulleys for this type of nonsense..
regular old WD40????
ecordell
CordellDesigns.com
Merica
Try some "chain lube" (made for motorcycle / 4-wheeler chains). That stuff quiets old rusted chains very well. I would just make sure that you didn't get it on the belt itself ;)
ecordell
CordellDesigns.com
Merica
How do you chance a belt? :idiot:
J/k man, I knew what you were trying to say.
fatnlowtahoe504
fatnlowtahoe504
yal dont think its the pulleys at all? i had the same problem on my old tahoe and i changed damn near everything..the belt, alternator pulley, water pump pulley, all kind of crap so ended up just saying f-it! but i hope it might just be the belt on this truck or maybe ill try some belt dressing??
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
if it is belt squeal change the belt.
otherwise it could be the idler pulley/ tensioner on its way out.
LazyAssLou
Houston, TX
Shit, winter here in Houston is like 60 degrees...
But my belt does squeak sometimes on cold starts. I should change it out this weekend.
Beefsolar
