I pulled the steering column, both front seats, and the dash out so I could check all the ground points and wires. the wiring on the column had some 1 inch spliced wires attached to several of the major 10-12ga wires. Guess they were using them to check for voltage or something. Removed those and put the wires back to normal. I have the harness laying in the floor. Noticed someone must have had a nice stereo at sometime found 2ga cables under the carpet and RCA jacks shoved up in the dash. There are a lot of those clips you put on wires to tap into them. So I am removing all of them and taping the exposed original wiring. Shot the grounds and the powers in the headlight switch they were fine. Still have the issue. Still searching. I guess I will start from the headlights and work my way through the engine harness area into the cab area. It has to be something simple and hidden real good. I did recently have the intake manifold out so maybe I nicked a wire on that portion of the harness. One ground attached to the thermostat housing is one of the common grounds he wipers and lights share. It shot good.
