wipers..and headlights...and turn signals
1999hoe
aka HOVERHOE
Massachoochoosetts
Yea front and rear go off when i turn lights they both go off and left blinker stays solid when i use left blinker the blinker flashes fast and they both go off also when i turn the headlights on the wipers dont turn off til i shut the truck off
SunlitComet
OBS Jedi-Do Good
unknown at this time.
the go for that wire bundle first and stretch out both direction looking for the issue after inspect the connector first obviously.
1999hoe
aka HOVERHOE
Massachoochoosetts
Well i cleaned the fuses under the hood and it seemed to fix the issue however i was messing with the bundle of wires near it and that might have done something also but so far they been working tested em a few times and they come on as they are supposed to without the wipers lol ....any pics of that connector woukd help tho
SunlitComet
OBS Jedi-Do Good
well you will have to work your way into the dash if the problem is in there instead. however cleaning the fuses should have no effect on the issue tho.
mattss90
Kingsburg, California
I had a similar issue and all it took for me was to change out the wiper module under the hood right behind the dash. You can either spend $80 on one or buy a $25 one on Amazon. Bought the $25 one and a year later it's still working properly.
Possum1
