Wireless car phone charger
Ron C
Ron C
Los Alamos, NM
got it, what I would have done is probably unscrew the tray and put it underneath it, that way the tray seems 'original' and the charger hidden/built in.
But the unit being that flat is definitely a plus, If what I am trying doesn't work (putting the electronics right underneath the tray, I might try the same thing as what you are doing.
Ron
Ron C
Ron C
Los Alamos, NM
hello all,
I bought one of these wireless chargers, from ebay, they are fairly inexpensive. I bought one with two coils, because I already noticed that these chargers want the phone on there "just right" I mounted it underneath the "cell phone tray" hooked it up to one of these USB chargers. I took the USB charger apart and soldered wires to where the contacts connected to the little board. ground goes to 'sheet metal' and the power wire I connected to a 'ignition key' activated tab, in that junction box near the brake pedal. I used duct tape to stick the coils to the tray, I think in this case it works better than glue, it can't really go anywhere. I drilled a hole in the lid underneath the cover to run the USB cable through. The hole is covered by the cell phone tray, and on the inside there's a trim panel.
It seems to be working really well, and it is an inexpensive 'upgrade' ($15 wireless charger, $4 for the car charger/adapter).
Here are a few pics:
Ron
20180624_115754.jpg 20180624_113750.jpg 20180624_122043.jpg 20180624_130040.jpg IMG_0720.JPG
sanco
Chicago
very nice, great job! I'm surprised this isn't done more with these trucks, it's cheap to do and you can either do a quick hookup like I did or a oem looking setup like you did. The convenience of the wireless charger is totally worth less than $20 in parts!
Again great job, looks good!!
Ron C
Ron C
Los Alamos, NM
Oh yeah I like it, no messing with plugging in cables, wires all over the place. of course it takes a little work to route the wires (that is always fun), but totally worth it and easy to do with a center console.
Ron
PPV12HOE
NC
I'd love to do this but my phone with the otterbox on it wont fit flat in the top section of the console... thinking I might do this in the front of the tray instead...
Walkinblessin
