Wiring for 1999 tahoe injector
exp500
Here is a pinout link for PCM Plugs.-
I cant find the Injector Diagram I'm looking for, but shows Ground distribution, connectors fuse and relay. Duck duck search wasn't too helpful tonite.
A Subscrption or a factory cd manual would be helpful to you. I'll post if I find it. You want to verify power to PCM, and grounds for PCM/injectors. You can test some wiring with above link, especially to/from injectors. If those OK you need new PCM.
exp500
A few more-http://lt1swap.com/1999_vortec_5.7/Power,Ground,%20DLC.gif
t1swap.com/1999_vortec_5.7/Fuel Injector Controls.gif
Good Luck, Hopefully bad ground. Post results
BaronUA
