Won't crank. Battery good. No codes.
CodeB4U
Houston, Tx
I have not checked either the starter voltage or the aux blinker fluid res levels. I will check the starter voltage next time it does it, but I'm relatively certain it has juice, since the top of the new cables have power. But you know how that goes. It is one more thing to rule out, right? I'll top off the blinker fluid when I get home.
Check it on the actual post, not on the cable or the nut.
Check your ground really good.
Bang the starter around.
There are other reasons this might happened but those are the "WTF who would of ever thought that" type of shit.
ravingmadman
ravingmadman
Chief Knuckle Buster
Greater Seattle
I did replace all of the wires that touch the battery, or have more than a couple amps going through them, including cutting and retermintating the one that goes across the top of the radiator to the aux post on the relay panel. Everything.
I couldn't hear the solenoid kick when I turned the key. That was what got me about it.
I'm sure there was a factory security system, but there was also a clifford alarm in it right before i bought it, and it looks like it was professionally installed, so I'm sure they killed the factory alarm. I'll have to look up info on the factory alarm though just to double check it though, because todd from burien was a really crappy electrician. Good call.
TahoeGoBoom
blue interior guy
is the clifford still in it? could be a starter kill gone bad.
ravingmadman
ravingmadman
Greater Seattle
The brain unit is gone, although it looks like only the brain has been removed. The siren, long-range antenna, etc., are all still in place. I've left them as a visual deterrent while I figure out on my other thread which alarm I'm going to buy/install. I don't know anything about alarms. Can someone tell me where the factory security system is, and where I should look for a starter kill box?
TahoeGoBoom
blue interior guy
the starter kill is a relay in the column. shouldnt really be a problem if the brain is out, and i really doubt it would fix itself. as for the factory alarm, i dont know much about em. mine didnt even have one. just keyless entry.
the only thing i can think is that these trucks use a passlock system that may be messed up, hence why pulling the ground fixes it. (resets the system)
Well Worn Chevy
