won't start
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Actually verify the pressure reading. the only thing that "shot up and hit the hood" tells me is that you might have seen a woman go by but not how good she looked.
N
nick8403
Yes getting spark and cranking like normal will run if I spray gas or starting fluid in in it
N
nick8403
When I first tested it it was 53 now its only hitting 10 even when testing it at the filter
SunlitComet
OBS Jedi-Do Good
uh, yeah either the pump power or ground terminal connections are breaking or if the connector is the old type that is failing, or your power supply fusing or switching is failing or your pump itself just took a dump.
retorq
Kingman AZ
It's not the pump, you have fuel spraying everywhere, remember?? Must be a blown head gasket.
N
nick8403
Nope not a head gasket I know that much I've fixed bunch of those and any car I've worked on or seen with one still runs with a blown head gasket but I bit the bullet and had to move it to a shop had to clear the room in the garage
dacpdx
