Would like 1-1.5" more height in the front
mitchn06
So taking my stock 2005 and doing suspension/wheels/tires, I'm still a bit low in the front. I would like a bit more. Starting out at 35in front and 36.5 rear, I added bilstein 5100s all the way around, moog HD rear springs in the rear, torsion bars cranked up (left 1/4in bolt hanging) 285/70R17 Nitto Terra Grapplers, I'm now sitting at 37 in the front and 39 in the rear. Is my only option at this point to get different keys? Are my T-bars possibly worn out? I do know I raised the back a bit with the new springs, but figured I could compensate with cranking the torsion bars, no dice. 65418cc3b1439b022ddcf9b8b6f20a70.jpg
M
mitchn06
Did you ever put lift keys in it or just crank stocks?
I only cranked the stock ones. I just don't want to overdo it and have front end parts that need replaced every 2-5 years.
01Konvict
Boats n Hoes
Raleigh/SML
Put lift keys and crank some. Get 5100 shocks. Level fenders and drive. No need that parts wear out fast at your height.
Knope
NC
I'm in the same boat right now. I cranked my torsion bar to where there are only a few threads showing and it rides too stiff for my liking (and it's still probably only stock height). I also have belltech sp shocks on since I was previously lowered. I went ahead and ordered the Bilstein 5100s last night for the front. From my reading, they should give a little lift from stock without the torsion bar adjustment. I'll post results once installed.
carloogbuyNuh
