Wrap All - Wrap Some - Wrap None
16blkltz
16blkltz
Installed plasti dip grill. We'll see if this look will grow on me. Like I said before....I prefer a smooth, glossier finish that this plasti dip grill does not have.
I was able to remove and replace grill without removing bumper.
BrianT
Looks good, but how did you remove the grill without the bumper having to come off??
16blkltz
16blkltz
I removed all clips and fasteners from top portion and all fasteners from left/right fender wells and removed the 6 fasteners that attach the grill to the bumper (3 on the left and 3 on the right). Then, unclip the 12 clips (these are just like hooks that snap into place when installing grill) from the bottom of the grill that attach to the bumper.
I was too lazy to jack the Hoe up to get under to remove the "gazillion" fasteners and clips...but I think it would've been a little easier removing them and removing the grill with the bumper. Those 12 clips on the bottom were a bit tricky to unclip.
16blkltz
16blkltz
I basically used the attached instructions and this video as my reference. I did not do steps 4, 5, and 7. And in step 8 they mentioned 5 screws, but only 3 on each end attaches to the bumper (you can see them in the video at around 5:33.
Also in the video at around 4:20, you can see the kind of space you'd have to stick your arms in to reach the 12 clips on the bottom of grill.
  • 6310561-installation-instructions.pdf
BK76
Love the look. Did you consider just leaving the grill on and taping around it? I have watched several videos on www.DipYourCar.com and they mostly taped around it and just sprayed right on. now I haven't found a video where they did a Tahoe (or anything but a car) but they always did the same thing. Just taped around and sprayed the chrome.
Just curios if you had considered and what your reason for removing was. (ie: the only option)
Thanks
BK76
16blkltz
16blkltz
Thanks
The reason is.....the grill was already off. The grill is a brand new grill I purchased from Ebay. If you notice, it's not the LTZ grill (with the horizontal slats). So I removed the LTZ grill to put on the Ebay grill that I had just plasti dipped and also applied 3 - 4 coats of glossifier.
16blkltz
16blkltz
BK76
awe... that makes perfect sense now. I have done the plasti dip on emblems for my Dodge Ram, but not for Trim or Grills. I am going getting all the product now so I can do this as well.
brian70068
