Xgauge comands and codes
saif najd
Hi all,
Tgis topic is for all xgauge comands and codes we have!
Please lets share by this way: (suggestion)
"What is the code for"
"The code"
Model: ...tahoe/Yukon..
Year:..97/98/99/2000
I well post mine as soon as I get home
Back!
From the site we get this info:
Below are the GM Specific XGauge codes.* They are broken down between the two ECU protocols that GM used, so you’ll want to program these XGauges based on what protocol your GM vehicle uses.* All 2003 and older GM vehicles will use the VPW protocol.*
All GM vehicles from 2004 to 2007 may use the VPW or CANSF protocol.*
All 2008 and newer GM vehicles will use the CANSF protocol.
You can determine what protocol your vehicle uses by pressing MORE > MORE > MODE on the ScanGauge while it’s connected to the vehicle.
Some sensors may not be reported by the vehicle.* If you try all available XGauges for a certain sensor and it doesn’t report any data then the sensor is most likely not supported by the vehicle.
Note: Sometimes the value 01 needs to be added to the end of a TXD to get the XGauge to work.* This is why there is a (01) at the end of each of these XGauge’s TXD line.
Sent from my GT-I9505 using Tapatalk 2
saif najd
saif najd
This from the official site but! Most of this codes didn't work with me
The A/F ratio worked showing 14.7 all the time never ever changed!!!
The transmission temp worked (but showing only Fahrenheit not C.)
Pleas do share more of your XGauge codes
saif najd
saif najd
Waiting :)
jgrundy13
