2021 Yukon Denali
TeamDenali007
Hello everyone, I need your assistance. I now have Nitto Ridge grapplers 285/40/22 tires, and I absolutely love the look and ride quality. However, with the new tires, my frontend points have lowered. Do you believe I should acquire a level kit? If so, what size should I get: 1" 1.5" or 2"? What brand and vendor should I get the kit from?
I have the 285/55R22 Nitto Recon Grapplers on my 23 Yukon. Close to the Nitto Ridge Grapplers. I had a 2" Rough Country level installed.
T
TeamDenali007
Niceeee 2023 is bad!!! Did you get the Ultimate? Can you share photos of your truck? Ill certainly look into the 55s.
olyelr
Elk Rapids, MI
Front points have lowered? Huhhhhh?
285/40/22 ridge graps? Do they even make that size? That is quite a bit smaller than the factory size tires.
How about a couple more pics? Also, any rubbing and does the tire stick out at all?
No rubbing, no cutting and no tire poke. Although I am considering wheel spacers for a little poke.2CEF433B-64CE-4C14-BE25-4F4A77E782B7.jpeg
ACPTECHS
