Adding USB to dash...
NathanJax
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Thanks man! I really like you write ups! Very good detail and information! Keep up the good work. Your ride is very well done!
Thanks!
:Handshake:
shundal
NorCal
Thanks for the writeup. Install was very easy and straightforward. I was able to run the mini usb from the cig adapter directly to my HRT iStreamer, which then outputs RCA to my headunit. Now I can plug my iphone 5 directly into the usb cig port and it will charge my phone and play my music while getting the better audio quality of having an external DAC.
I purchased the usb port and cover for $33 shipped off ebay. http://www.ebay.com/itm/NEW-GM-USB-OUTLET-RETAINER-W-COVER-AND-USB-SILVERADO-SIERRA-20983937-20944422-/261115610583?pt=Motors_Car_Truck_Parts_Accessories&hash=item3ccbb405d7&vxp=mtr
blkonblk
NYC
This is something I'm very interested in doing, I believe Nathan said this will not work for 2008 Tahoes correct??
NathanJax
NathanJax
Vacation Nathan
Administrator
Jax, Fl
depends...
Factory radio?
Do you have Factory Nav?
Do you have USB already in your center console?
YuCanada
Nunavut, Canada
Hey Nathan, Id like to do this - I have a 2007 Yukon slt with factory nav, but I dont have a usb plug in the console. is there one behind the headunit?
AJ847
would this work with my 2009 ltz with stock navigation head unit? How would I get it to interact with my iphone, ie: charge, play music?
yates ™
Resident Apple hater
Iowa
If your stock radio has USB there will already be a USB plug in the console if not you will need to do an aftermarket radio.
YuCanada
Nunavut, Canada
I ended up getting one, and just plugging it into the 12 volt behind the trim with a usb 12 volt charger. So I have the port now, but it's just a charger.
cervantesjesus174
