07 tahoe z71 BILSTEIN rear shock
Trey Hardy
Eastern North Carolina
The coil springs have been used for about 200,000 miles.
I feel tired and weak.
Is Bilstein 5100 24-185783 recommended as a choice?
Desired lift is 1.5-2inch.
Bilstein 5100 Series Set of Rear Shocks fits 2014 2018 Silverado 1500 4WD with 2" Lift | Includes TrendsAuto Decal | 24-285896 https://a.co/d/9sqWL3g
These are the ones I used when my Tahoe was leveled it says for a Silverado but they work on the rears from 99-18 or higher
Sawa
Sawa
thank you! Can this be used with a z71 coil spring without a spacer?
man n black
Does this truck have auto rear level?
If so you do not need any kind of rear lift as when you lift the front via a torsion bar lift keys it wil automatically raise the rear of the vehicle. This will gain you between 1 and 1.5 inches of overall lift. Only shocks are needed.
Sawa
Sawa
1.5-2inch lift
Which one should I choose?
BILSTEIN 5100
24-185783
Compressed
Length
16.12"
Extended
Length
26.14"
Shock Travel10.02”
24-187237
Compressed
Length
15.55"
Extended
Length
24.33"
Shock Travel8.78”
24-285896
Compressed
Length
16.57
Extended
Length
26.20”
Shock Travel
mikez71
first one has the most travel.. third one only has .06" more length..
My pick would be #1 (24-185783) unless #3 has some other advantage..
Park60
