2003 Tahoe 5.3 VIN-Z - P0300 With a Twist
M
mridgewayii
SWAG I wonder if the O2 heater circuits are working. If not, it could prevent the sensors from coming alive. But I think there's a code for that. (?)
I agree and I thought that in the beginning but after driving it 10-15 miles … I would think the O2 sensors would have been hot enough
Tonyv__
Bucks county PA
Well, your post made up my mind. I’m going to pull the valve covers this week to see. I’m pretty competent at troubleshooting and can’t remember a time something had me this stumped. Time to go back to the basics and see if the mechanical parts are working.
Keep us updated and good luck
Think, but know. I'd be testing the heater circuits to make sure they can carry the load. Several YouTubes out there showing how using a test light that draws some current.
Mudsport96
40.923,-89.488. Illinois
If you can get a helper looking at moving rockers is easier.
Remove coil packs and valve covers and pull the fuel pump relay. Have helper crank the engine while you watch rockers. Look for any that aren't moving a whole lot, or seem to have slop. Otherwise, use a socket and breaker bar to rotate and check for slop in the rockers.
V327839
I had an intermittent limp mode issue for the longest time. I could even fix it just by slamming the drivers door on occasion. Since you’ve done so much work to your engine, I would check the place I found my problem. The underside of the main harness as it crosses the intake manifold. In my case, the engine cover has squashed some wires to the point I had a bunch of shiners. After some wire repair, the issue was fixed. It’s worth a shot as I found that the main harness as it’s pulled across the manifold is very tight and rubs in several places, especially if you’ve moved it yourself. You’ll never get it back perfect. Thats my experience.
Leno1364
