Passenger side brake light
gbleezy
loves to snowboard
I replaced my tail lights with LEDs years ago. The tail light works and so does the turn signal, it's only when I press the brake pedal it no longer lights up. I checked all related fuses and they're all good. Any ideas what else I should be checking?
wjburken
Eastern Iowa
I’d check to make sure your LED didn’t take a dump.
I’m assuming it is lit and then when you hit the brakes it goes out instead of going brighter.
What about when you use the turn signal?
gbleezy
gbleezy
loves to snowboard
It's a whole LED housing but yeah, turn signal works and the LEDs are lit up when I turn the lights on, they just don't get brighter when I press the brake pedal and it's only the passenger side.
petethepug
Michael
SoCal
If they were inexpensive it’s time to replace it. Unfortunately you’ll have to buy the set (again). Moisture has probably contaminated the ICB that controls the brake light portion
Matthew Jeschke
Sahuarita, Arizona
I believe your brake lights are separate bulbs. I'd test them in another fixture / vehicle to see if it's really the bulbs. Otherwise, I believe there's a brake switch for the lights and of course the wiring. Try another bulb (just get a cheap one) and or test those in another fixture first.
Or maybe I'm confused, is that a whole assembly? Did you modify the wiring for that setup?
gbleezy
gbleezy
loves to snowboard
It's a whole housing and the only bulb that is separate is the reverse light bulb. It's all plug and play. I was thinking it could be the brake switch but wouldn't all the brake lights not work if it was a faulty brake switch? The LEDs still work because the turn signal works and the tail lights still work. I checked the fuses with a fuse tester and they're good, but I may just replace them anyway.
petethepug
Michael
SoCal
Buy the exact same ones and return the broken ones. They should last longer than that.
gbleezy
gbleezy
loves to snowboard
I bought them 10+ years ago. I don't even remember where I bought them from since it's been so long.
steve45
Can you swap left and right to verify that the right side is working correctly? Don't drive it, of course, just plug them into the harness and try them in your driveway.
arkie
Check your turn signal switch
Jmily8474
