cobbcfi
This is a new thread based on my other thread because that thread is no longer applicable, the rear-end and hub bearings are clear and working fine.
Upon crawling underneath the middle of the truck under the transfer case with the engine running in 2H drive 1 I can see the front drive shaft rolling around at the transfer case output shaft. I can move it at least 1/16" in all directions and it's definitely where the sound is coming from.
What has happened?
How I know what type of transfer case do I have?
What are my options? Repair/Replace
Do I have that dreaded busted snap ring?
Has the possible snap ring caused the T-case fluid to drain and ruined it?
I still have 4H because I used it to move the truck with the rear shaft out.
I still have reverse.
My 4x4 lights on the console don't work, I replaced the switch a while back and it didn't fix it.
This Yukon is my only means of transportation so please help me..
What has happened?
