UPDATE on 8" Shallow Mount Subwoofer drivers to fit in 01-02 OEM box
If you go to their website and look at the enclosure there's an install file pdf under support files. It shows them cutting out for the grill which looks to be included. It says there's a template. What's not clear is if they're talking about just modifying the existing speaker hole in the cover or what. I assume you're talking about cutting the plastic cover panel? I would suggest getting ahold of MTX for clarification.
YukonXL04
The Riverboat
Arlington, TX
According to the MTX install guide there is a included grill and template for it. you can also take a dremel and cut out each individual hole on the factory grill. Either or. Also you could take a factory cargo panel from a 99-02 that has the holes already cut into it and just swap panels. 3 different options for you.
treehan77
TYF Fiend
Crestview, FL
huh cool, hopefully i can find one of these mtx enclosures cheap, they want a pretty penny...or i'll have to build one
I got my enclosure today and the included grill is definitely meant for the factory cutout- it's a beveled piece that fits where the factory cutout is countersunk. I'd suggest either mounting a regular grill or finding a stock panel that has the sub cutout. I can provide a picture if needed.
TheAutumnWind
On my 03 Tahoe, I was able to find a factory rear sub box at of a 01 Tahoe and mounted it in the rear cargo area just like it was factory from 00-02. I did a JBL 8" swallow mount as well. So not only do I have the factory sub in the center console on my 03, but a bit extra "Thump" coming from the rear.
I like this idea.
crazycrew
Vacherie, LA
Hmmm. Any certain tahoe or yukon I should look for to get this factory box out of?? I have a loaded LT, but from the looks of the panel (no holes cut out), It doesn't appear to have the oem subwoofer. 2004 Tahoe
treehan77
TYF Fiend
Crestview, FL
01-02 like the post title says
ge0rgin0
EL CHUCO, TX
Do you mean the Denali XL?
Or do you mean the Denali short wheel base?
The MTX Thunderform doesen't fit the Denali XL because it is a long wheel base, and the factory space for the rear mounted hidden subwoofer is constrained by the cubby hole directly above the sub. Since this cubby hole is formed into the factory rear quarter panel plastic trim, it is impossible to look stealth, or look factory, but cutting the entire quarter panel out. MTX never offered a Thunderform for the Denali XL, Yukon XL, Suburban, nor the Cadillac ESV.
The MTX Thunderform DOES fit the short wheelbase Denali, even though you may have read that it doesn't. The unit actually does, but to install it requires moving the Denali amp that is in the way.
The factory BOSE amplifier is the key difference between the Tahoe / Yukon short wheel base, versus the Denali / Escalade short wheel base. In the Tahoe and Yukon, the amplifier is located up front behind the glove box in the 2000-2002 models. However, in the Denali / Escalade of the same '00-'02 years of the GMT800 body style, the luxury amplifier is larger, and is located in the rear of the vehicle, on top of the factory Bose sub..
The fact that this Denali amp needs to be relocated to fit the MTX Thunderform is most likely the reason why you may have read that it doesn't work in the Denali.
However, remember that cubby hole I mentioned earlier? The cubby in the Suburban and Denali XL that is directly on top of the factory sub in the long wheel base vehicles? The cubby hole that gets in the way of installing an enclosure with enough internal volume to support a 10" driver?
Well, in the short wheel base Denali, as well as the Tahoe and Yukon, the factory cubby hole is more forward over the rear wheel well, instead of on top of the factory subwoofer, where the amp in the Denali is. Therfore, if you take the rear factory amp in the Denali that is on top of the sub, and move it INSIDE the cubby hole that is on top of the wheel well, then the MTX Thunderform will fit perfectly in the Denali.
When you move the amp forward, just swivel it around 180 degrees, so that the plugs into the amp essentially stay in the same general location. Fortunately, the Bose amp electrical connectors are all on only one side of the amp, not two. So by pivoting the amp around 180 degrees, no extensions of any wire harness is needed.
A TYF member named Jeff did exactly this. His user name is JustPlayInn. Here are some photos he took of his installion of an MTX Thunderform into his short wheel base Denali:
BEFORE, with Factory Bose Sub, and Factory Bose Y91 LUXURY Amp on top:
________
BARE, after factory sub and amp and bracket all removed. NOTICE the GM OEM "Dynamat Extreme" installed at the factory directly behind where the subwoofer mounts (on the gas filling port bump in of the sheet metal):
________
BOOM, with the MTX Thunderform 10" hidden blast box in place, fitting perfectly in the Denali short wheel base (Jeff installed a Polk Audio driver instead of going with the MTX driver)... only the factory amp is MIA:
________
BAM, with the Bose factory amplifier cleverly swung around 180 degrees so as to maintain the factory wiring harness lengths, with a connector port hole drilled in the aft end of the cubby hole, and the stock amp fitted perfectly in place:
_____________
BONE stock look after the job is complete:
_______________
Photo credit: All photos from "JustPlayInn" (Jeff), and this was his installation as well.
Like I said in a previous post, if I had a short wheel base, Denali or otherwise, I'd be inclined to go with the MTX Thunderform. You can get it as a bare box and put in your own driver, or as a loaded box, with the MTX driver, or as a full package deal with the box, the driver, and the amp for the sub built in. This latter fully packaged version is what I would do personally, because there is a lot of value in a pre engineered solution. Having to find a place to hide yet another amplifier is something I'd rather avoid, so why not get one built into the box itself?
Sick Install ..still have it?
brittyboop0510
