05Single's virgin build thread. 03 tahoe
05Single
05Single
afraid of the dark
Yea I couldn't bring myself to doing the cheap way, my ocd would go crazy knowing I have wires just laying in the fuse box. I know that way works perfectly but I just prefer this option. This is a clean look, and yes expensive but I'll be getting some use out if it this winter.
$20 is worth it to me
They don't make that board for my 02 anyway, plus it makes it impossible for my full time DRL mod.
Smoke Em All
Taylor,Texas
I only used the diodes no wires. It's a relatively clean setup.
05Single
05Single
afraid of the dark
Yea that's the thing , only for 03-06 with no plans on making any for 02- or 07+
Smoke Em All
Taylor,Texas
I added switchbacks and yellow coated bulbs to the fogs.
I later got plugs from a salvage yard and deleted the drls and in place wired in another set for parking lights and turn signals for a whole row of switchbacks.
What do you mean by switchback? What bulbs did you use in the park lights.
osiris94ej
Casper Wyoming
The 4 high mod for the 99-02 trucks and 01-02 suvs is just to ground the yellow wire on either side of the headlight harness. I used a t-tap, a short piece of wire(maybe 8" of 16ga), simple crimp on ring terminal. I ran that to the bolt that holds the battery brace on. Used the t-tap on the yellow wire on the low beam. Turn on lows and flip on the high and the low should stay on.
Sent from my SM-N920V using Tapatalk
ElMasBuscado23
