Installed resistors to get rid of Service Suspension message after removing Autoride.
JT 07LTZ
Western, NC
I recently replaced all 4 of my autoride shocks with Bilstein 5100 shocks. To turn off the "Service Suspension" DIC message, I installed a resistor on each of the wires that used to connect to the Autoride shocks.
The resistors are: 3.9 Ohm 25 Watt 5% wire wound. I bought these on Amazon.
Here is where I prepped the resistors by soldering and heat shrinking some wire on to each side: 20161216_164648.jpg
Then I cut the connectors off each wire that used to connect to the Autoride shocks and connected one resistor in each of the 4 corners of the truck. I heat-shrunk all of the connections to protect against water etc.
An example of the front driver side:20161225_150658.jpg
An example of the rear passenger side: 20161225_144325.jpg
Then I tucked them up into safe spots and zip-tied them to the frame.
This has successfully turned off the DIC message for me.
01Konvict
Boats n Hoes
Raleigh/SML
Thanks for posting info and pics for resistors deleting auto ride error message. Nice solder heat shrink work. It should last a very long time with that connection. Do you have a link to the resistors from amazon?
mportkiller
Did you pull any fuses? If you did, which ones?
Sent from my SM-N920V using Tapatalk
mportkiller
I tried both ways and I still get the service suspension warning. I used these resistors, but I put one on the compressor too. I am gonna remove that one though, because since I did it, my lights are flickering.
01Konvict
Boats n Hoes
Raleigh/SML
There are fuses under the hood. Look up manual and locate fuses. Resistors only go on shock wires.
brasil
just in case... I have a 2001 Tahoe with autoride. Are the resistors the same ?
Greetings Juergen
Btw.... Nice Truck and good work !
mportkiller
I have read that thread previously, so yes I was able to use the search function. I still had questions about the resistor and if I needed to remove the compressor fuses too. What about ride height sensors? Anything need done with that? I have put the resistors on all 4 shocks and removed the fuses, but I still have the service suspension warning.
Chris_from_cincy
Here is where I prepped the resistors by soldering and heat shrinking some wire on to each side:View attachment 71443
An example of the front driver side:View attachment 71444
An example of the rear passenger side: View attachment 71445
What GA wire did you use? is that .10GA?
klathan2015
San Jose, Ca
I have a 2013 Suburban 1500 4WD LTZ that had the Z55 suspension. I switched to Fox Shocks.
I used 4 - 50 watt 1ohm resistors on each corner; my Service Suspension light was still on. I used 4 - 25 watt 3.9ohm resistors. Service Suspension light came on.
Im not sure what to do next. I just thought I'd share my experience. No luck
str8wire
Do you like the Fox shock? and were you able to get the service light off? I have a 2008 Suburban 1500 LTZ and was thinking about your setup.
Thanks
klathan2015
San Jose, Ca
The fox shocks are awesome. The warning message on the dashboard still pops up. I've jus grown to see it as normal.
35inch tires
20inch wheels
4inch BDS lift Kit
Fox shocks with DSC adjuster
Coolman1987us
Maine
If you pull the fuses for any part of the autoride it will throw the message up on the DIC. If the suspension control module above the spare tire gets compromised (like my 08 did) it will short out internally and if you're lucky it will only throw up the message. My hoe almost went up in smoke along with no comms to anything on the CAN bus. Google tahoe suspension control module fire. I completely removed my module after i saw that. Just clear the DIC when you start the truck for the first time.
Writefast
Just posted about auto ride. I swear to god if I go under there tomorrow and find one of these resistors I’m going to buy a 3in lift kit! Maybe. Mostly maybe. Will have to compare prices. lol.
