Installed resistors to get rid of Service Suspension message after removing Autoride.
JT 07LTZ
Western, NC
I recently replaced all 4 of my autoride shocks with Bilstein 5100 shocks. To turn off the "Service Suspension" DIC message, I installed a resistor on each of the wires that used to connect to the Autoride shocks.
The resistors are: 3.9 Ohm 25 Watt 5% wire wound. I bought these on Amazon.
Here is where I prepped the resistors by soldering and heat shrinking some wire on to each side:20161216_164648.jpg
Then I cut the connectors off each wire that used to connect to the Autoride shocks and connected one resistor in each of the 4 corners of the truck. I heat-shrunk all of the connections to protect against water etc.
An example of the front driver side:20161225_150658.jpg
An example of the rear passenger side: 20161225_144325.jpg
Then I tucked them up into safe spots and zip-tied them to the frame.
This has successfully turned off the DIC message for me.
01Konvict
Boats n Hoes
Raleigh/SML
Thanks for posting info and pics for resistors deleting auto ride error message. Nice solder heat shrink work. It should last a very long time with that connection. Do you have a link to the resistors from amazon?
mportkiller
Did you pull any fuses? If you did, which ones?
Sent from my SM-N920V using Tapatalk
mportkiller
I tried both ways and I still get the service suspension warning. I used these resistors, but I put one on the compressor too. I am gonna remove that one though, because since I did it, my lights are flickering.
01Konvict
Boats n Hoes
Raleigh/SML
There are fuses under the hood. Look up manual and locate fuses. Resistors only go on shock wires.
brasil
just in case... I have a 2001 Tahoe with autoride. Are the resistors the same ?
Greetings Juergen
Btw.... Nice Truck and good work !
rsyoder96
